Oriental Tech spring-over-membrane
(Redirected from Oriental Tech linear)
Jump to navigation
Jump to search
Manufacturer | Oriental Tech? |
Switch type | Progressive rate |
Sense method | Spring-over-membrane |
Rated lifetime | 10 M |
Actuation force |
60±20 cN (standard) 90±25 cN (space bar) |
Pretravel | 2±0.6 mm |
Total travel | 3.5±0.4 mm |
Keycap mount | Alps mount |
Switch mount | Moulded to mounting plate |
Oriental Tech spring-over-membrane is a provisional name for a type of switch presently only recorded as being in keyboards from Oriental Tech. It is a progressive-rate spring-over-membrane design, with an exterior return spring placed under the keycap. The manufacturer is not known, but it's likely that it was an in-house design by Oriental Tech, for their OK-100 series of keyboards.
Gallery
Specifications from an OK-100M keyboard
